Ohio Pickling Facility Adds Top/Bottom Coil-Inspection System
November 1, 2012
The Samuel Steel Pickling Co. facility in Twinsburg, OH, has installed an ISRA Vision Parsytec inspection system to perform 100-percent top and bottom inspection over the complete surface of each coil. The unit identifies and classifies surface defects and generates surface-inspection reports.
Additionally, the facility also recently acquired an inline Butech Bliss leveler, designed to remove flat-coiled shape defects such as coil set, crossbow, edge wave and center buckle. It’s rated for leveling 0.060- to 0.26-in. sheet to 72 in. wide. And, coming soon to the facility: a circumferential coil-strapping machine.
Industry-Related Terms: Center, Edge, Surface
See also: Butech Bliss, Isra Vision Systems Inc.
Technologies: Quality Control
