The Science of Forming
Introduction to Strain Analysis: The Forming Limit Curve
By: Daniel J. Schaeffler, Ph.D.
Danny Schaeffler, with 30 years of materials and applications experience, is co-founder of 4M Partners, LLC and founder and president of Engineering Quality Solutions (EQS). EQS provides product-applications assistance to materials and manufacturing companies; 4M teaches fundamentals and practical details of material properties, forming technologies, processes and troubleshooting needed to form high-quality components. Schaeffler, who also spent 10 years at LTV Steel Co., received his Bachelor of Science degree in Materials Science and Engineering from the Johns Hopkins University in Baltimore, MD, and Master of Science and Doctor of Philosophy degrees in Materials Engineering from Drexel University in Philadelphia, PA. Danny Schaeffler Tel. 248/66-STEEL E-mail ds@eqsgroup.com: or Danny@learning4m.com
Tuesday, March 26, 2019
Using strain analysis, you can test the degree of stamping-process robustness as it relates to the sheet properties of the incoming blank used to form the part in question. The March 2019 Science of Forming column (viewable at www.metalformingmagazine.com) discussed measuring strains. Here, we begin to lay the groundwork on how to interpret the measured strains.
In sheet metal stampings, failure occurs before fracture, before the stamping no longer can hold water. Failure in stamped parts is associated with the formation of a neck or smile, since this represents the region where strains increase locally and the remaining sheet metal does not continue to deform in concert with the punch face.
Representative forming limit curve for mild and conventional high-strength steel.
Every sheet metal product has a limit to which it can be deformed before it splits. If your stamped part takes the shape of a dog bone, then you might be able to use uniform elongation, determined in a tensile test, to represent your maximum allowable design strain. Chances are, however, that your part is more complex.
The maximum major strain as well as the associated minor strain at each location defines the maximum amount that sheet metal can be deformed before necking. In experiments conducted since the late 1960s, different shapes encompassing a range of minor strain conditions were deformed to just before and just beyond failure. Researchers, including Dr. Stuart Keeler (founding author of this column), measured the strains on these parts and plotted them on a graph of major strain versus minor strain, creating the forming limit curve (FLC). The FLC represents the boundary between neck-free and necked conditions, as the image shows.
Selecting the FLC for Simulation
One goal of new-product development: All forming strains lie below the sheet metal’s forming limit. Selecting an FLC is a critical step when conducting a computer-based forming simulation as part of this process. Steel and aluminum producers supply simulation-software providers with alloy-specific data to incorporate into the material cards shown in their database libraries. Select the appropriate card if you know the source of the alloy. Some choices might be shown as the trademarked name of a particular alloy. Select that option only if that is what you are using. Understand that different suppliers do not produce advanced alloys in the same way. By extension, such materials can behave differently when formed.
Proper simulation becomes more challenging when the material producer has not provided a material card, or worse yet, the producer is unknown. Avoid selecting a product shown only by a generic description, such as 6XXX aluminum. Not only does this ignore the forming differences between suppliers, but it does not factor in the effects of temper—T4, T6 and T82, for example.
A particular danger stems from the ease of use of most simulation programs. Most provide the option of inputting the n-value and thickness, and the software calculates the FLC. It’s a great option—but only when using mild steel or conventional high-strength steel. For other alloys, this shortcut will produce inaccurate results.
The Shape of the FLC
The shape of the FLC, consistent among mild steel and conventional high-strength-steel grades, takes the general shape of a checkmark. The left-hand side features a slope of -1 in true-strain space, while the right-hand side exhibits a slope of about +0.6. FLC0, defined as the lowest point on the FLC, typically occurs near where the minor strain is 0. The value of FLC0 determines the location where the FLC is plotted on the graph.
Based on empirical data collected by Dr. Keeler, FLC0 for mild and conventional high-strength steels is a function only of the sheet metal thickness before forming and the n-value (strain-hardening exponent), calculated as:
FLC0 = (23.3+360t) x (n/0.21)
where t represents the sheet thickness in inches, and n refers to the n-value, or:
FLC0 = (23.3+14.2t) x (n/0.21)
where t represents the sheet thickness in millimeters, and n refers to the n-value. N-value has a larger effect than thickness, and both increase FLC0, which, in turn, is reflected in greater formability.
The shape and placement of the FLC for most other materials, including aluminum alloys, stainless steels and some advanced high-strength steels, cannot be represented by a simple curve or a universally applicable equation. For these products, a curve must be established for each grade and thickness combination. The method used to generate the FLC influences the results, so care must be taken when applying it to your analysis. These curves can be generated in several ways, including the international standard ISO 12004—Determination of Forming Limit Curves in the Press Shop (Part 1) and in the Laboratory (Part 2).
The properties and condition of the subject sheet metal also influences the FLC. In addition to tensile properties, other common influences on the curve include the sheet metal surface profile, the chosen lubricant and the testing temperature. Although collecting the data for these curves at a strain rate typically seen in a tensile test is easier, manufacturing a production stamping results in a strain rate 1000 times greater. Select the test parameters for FLC generation to best replicate the conditions used in the manufacture of your part.
Incorporating the wrong FLC into an analysis may lead to overdesign and unnecessary cost, or to building stamping tools that cannot consistently produce good parts.
Want to learn more about different sheet metals and formability? Plan to attend PMA’s Sheetmetal Formability of Steel, Aluminum and Stainless Steels seminar in Grand Rapids, MI, June 11-12. To register, visit www.pma.org or contact Marianne Sichi, for information. MF
See also: 4M Partners, LLC, Engineering Quality Solutions, Inc.
Posted by: Carl Lovre on 4/4/2019 7:19:59 PM
Danny, You have hit on the most important aspect of software based formability analysis. Having accurate material properties to enter into the simulation. It is also the hardest thing to acquire especially when working for a supplier of an OEM. They usually don't want to share them so you end up using generic material properties. When I worked at one OEM we had material properties that were tested and proven. Our simulation results were spot on compared to the real world. It gives you great confidence in the simulation results and makes them that much more valuable. Just as you pointed out, you don't overdesign your tools and you have tools that produce consistent results
YOUR NAME *
EMAIL *
WEBSITE
