Previews
Modular Fixturing Systems
Thursday, October 1, 2015
Bluco Corp.
Booth 11025
Bluco Corp., Aurora, IL, showcases its line of modular fixturing systems. Demonstrations are available for welding and machining applications. The company’s modular fixturing system for welding is ideal for fixturing low-volume/high-mix work. With the introduction of the rollover positioner and workstation bases, the benefits of this modular tooling can be extended into more manufacturing operations.
The rollover positioner provides the ability to rotate parts 360 deg. and still handle unlimited configurations using standard locating and clamping components. Workstation bases bring the full functionality of modular fixturing to small weld cells.
www.bluco.com
See also: Bluco Corp
YOUR NAME *
EMAIL *
WEBSITE
