Solar Atmospheres Adds 10-Bar Furnace
July 1, 2018Comments
Solar Atmospheres, Inc., Hermitage, PA, has added a $1.8-million vacuum furnace designed to quench with argon at 10 bar using a 600-hp variable-speed motor running at 460 V. The goal of the massive quench system by Solar Manufacturing, Inc., Souderton, PA, is to quench larger batches of power-generation castings by increasing the cooling rate and eliminating the supplemental use of helium. The furnace incorporates Solar Manufacturing’s SolarVac 5000 control system, which allows for complete process automation.
See also: Solar Atmospheres
There are no comments posted.Piab Introduces piClassic Neo Next-Gen Vacuum Pump
Tuesday, June 24, 2025
Yaskawa America Announces Expansion and Relocation of North ...
Thursday, June 19, 2025
Magnetic Tool Changers and Transporters, and Lifting Magnets
Tuesday, June 17, 2025
