Ride the Waterjet-Cutting Technology Wave
September 19, 2011
Omax Corp., Kent, WA, showcases its abrasive-waterjet product offerings , including the 80X JetMachining Center equipped with an EnduroMax pump and Tilt-A-Jet cutting head, as well as its Maxiem 1530 JetCutting Center with a multi-axis A-Jet accessory and a powerful direct-drive pump. Ideal for precision machining of larger or multiple parts, the 80X JetMachining Center is equipped with the patent-pending Intelli-Trax, an innovative drive system developed specifically for abrasive waterjet machining to ensure high accuracy. The Intelli-Trax traction drive reportedly enables faster traverse speeds than traditional drive systems, and reduced processing times when machining multiple and nested parts.
See also: Omax Corporation
Technologies: Fabrication
Related Content
