Hydraulic Plate-Bending Rolls
October 1, 2018Comments
Cole-Tuve, Inc., the exclusive North American distributor for Sahinler, will showcase Sahinler 4R HS hydraulic, four-roll double-pinch plate-bending rolls with two-roll drive. Both the upper and lower central rolls are driven by a hydraulic motor through a planetary gearbox, which reportedly provides for easier rolling and superior results.
The 4R HS has hydraulic adjustments for the rolls and the drop end, and standard features include induction-hardened rolls, two rolling speeds, a cone-bending attachment and three electronic digital readouts on a mobile control console. Sizes range from 3 to 13 ft. with capacities of 5/32 to 5/8 in. The 4R HSS model reaches to 20 ft. with capacities from 5/16 to 3-3/8 in.
Options include NC control, upgraded NC control, CNC, hydraulic overhead and side supports, and the machine can be further modified to customer requirements.
See also: Cole-Tuve, Inc.
Technologies: Fabrication
There are no comments posted.New Abrasives Line Includes Flap Discs, Quick-Change Discs
Tuesday, May 7, 2019
