New Products
Dampening Reduces Wear on Tooling and Pneumatic Press
Friday, May 1, 2009
Airam Press Co. Ltd., Covington, OH, a pneumatic press manufacturer, has developed a special dampening material for its presses that reportedly will help stampers improve parts production and reduce tool and press wear by nearly 30 percent. The dampening material is available as an option on Airam B-, P- and G-series pneumatic presses, in capacities from 3 to 210 tons.
Conventional presses typically contain areas where steel touches steel. The dampening material is placed in these areas, such as the space between the bed and the stand. During a part run, as the bed deflects the dampening material absorbs energy. Because energy no longer is absorbed through steel, the material reduces vibration by as much as 80 percent, according to company officials.
Airam Press Co. Ltd.: 937/473-5672; www.airam.com
See also: Airam Press Co. Ltd.
