Success Boils Over When Deep Drawing Replaces Hydroforming
VIDEO: All-Clad’s Robotic Blanking Cell and Greenerd Deep-Draw Hydraulic Press
Until mid-2011, All-Clad had outsourced to a hydroforming shop 25 percent of the pots and pans it makes. Much of the outsourced metalforming comprised five of the firm’s biggest hitters, which exceeded the company’s inhouse capabilities based either on blank size or tonnage. After a concerted and highly successful effort made by the company’s manufacturing operations in Canonsburg, PA, to move from batch manufacturing to one-piece flow, completed in 2010, the firm set its sights on bringing production of the hydroformed products inhouse. But rather than stick with hydroforming the large blanks—as large as 24.25-in. dia. used to make a 12-quart stock pot—the firm turned to deep drawing in a hydraulic press.
Boost press capacity it did—with the acquisition of a four-post 560-ton hydraulic press from Greenerd Press & Machine Co., Nashua, NH. The press joins two other hydraulic presses in the firm’s forming area, 160- and 120-metric ton models.
“Until 2005, we produced all of our pots and pans using hydroforming,” recalls DeHosse. “We added the two lower-tonnage hydraulic presses to move a from hydroforming, due to the blank-size reductions we could realize. All of our dies iron the sidewalls using a negative clearance, which allowed us to reduce blank sizes by 20 to 25 percent.”
How much blank ironing occurs? On a 12-quart drawn stockpot, for example, the hydroforming blank measured 24.25-in. dia. Now, deep-drawing the part (8.375-in. draw) in the Greenerd press requires only a 20.75-in.-dia. blank. The bottom thickness of the part remains the same as the blank, while the sidewalls thin by nearly 20 percent.
Feeding Blanks to a Hungry Press
A three- or five-ply pack (master blank) as large as 2 by 4 ft. can be quite heavy and challenging to manipulate. As such, All-Clad had grown weary and concerned over numerous strains and sprains experienced by operators plagued with indexing the packs along two- to four-out transfer blanking dies. In 2010, the firm automated the blanking process by installing a blanking cell starring a six-axis Fanuc S-430i robot (104-in. reach).
“The robot’s end-of-arm tooling (pneumatic grippers from PHD) features the lowest-profile tools I could find,” DeHosse says, “identified through my previous experience with tooling Trumpf CNC presses. We did have to modify the die rings on a few of the dies to add clearance for the grippers.”
Other cellmates include a five-roll straightener, a 150-ton 30- by 36-in. Aida mechanical press and a 4-ft. Tennsmith shear.
“To secure the layers of material during the cladding process, we add a series of resistance welds along one edge of the pack,” DeHosse explains. “After the robot picks up the straightened pack and indexes it through the blanking press, it moves the web to the shear to cut a a ¾ in. strip where the welds are. This allows us to separate the layers so we can maximize the scrap value.”
Blanks feed from the press at up to 60 strokes/min. “We change blanking dies as many as three times/day,” adds DeHosse, who notes that changeover time has been reduced to less than 30 min., compared to approximately 90 min., thanks in part to the recent addition of a magnetic upper bolster.
Before the blanks find their to the hydraulic-press department, they’re processed through an eight-station automated deburring operation.
Meet the Press
At the new Greenerd hydraulic press, we watched DeHosse form 7-qt. stock pots; a 7.75-in. draw reduces a 17.75-in.-dia. blank to an 8.4-in. dia. pot. “We do everything in a single draw,” notes DeHosse, “with a stationary form ring in the upper ram, the punch mounted stationary in the press bed and a floating cushion.”
Press specs: 36-in. left to right and front to back; adjustable force from 112 to 562 tons; adjustable stroke to 40 in.; ram speed to 912 in./min. on close and 95 in./min. during forming; cushion force adjustable from 28 to 280 tons, with a 16-in. stroke; 20-ton ejection force; and ram-mounted knockout force to 30 tons.
Rather than design the press with an integral blankholder, each tool features its own blankholder. And while DeHosse says that the drawing process would function similarly whether the blankholder was mounted to the press or tool, there is one distinct advantage to having it in the tool.
“With the blankholder on the tool,” he says, “we can set a very low blank-holding force, since we’re using purely hydraulic valving to control the force, independent of the weight of the ram. If we hold these blanks too tightly, we’ll experience stress cracks and fractures at the top of the draw. By reducing blankholding force, we promote better material flow throughout the drawing operation.”
Die work—new builds and maintenance—is performed by a local shop, AccuDie Inc., Meadow Lands, PA. “AccuDie functions as our external toolroom,” says DeHosse. “Our projects take priority; they’re in here three to four times per week picking up and dropping off. Of particular concern are the draw rings (of Ampco bronze); they see a lot of heat and oxidation from the stainless steel. That oxide buildup has to be removed and the rings polished every 2000 to 3000 draws.”
Ram-stroke settings are controlled by digital linear transducers, “and the end-of-draw repeatability with the Greenerd press has been spectacular,” shares DeHosse, noting that “we don’t draw to positive stops, we draw to ram position. With our other two hydraulic presses, we experience significant drift during drawing. With the new press, if we need to reduce draw depth by 0.030 in. we adjust the program and rest easy knowing the accuracy and repeatability will be there.”
Also included with the press: a bar-code reader that operators use to scan the dies and call up the appropriate forming recipe; and light curtains across the front of the press with mirrors along the back to reflect the curtain and completely guard the press perimeter.
Consistent Lubricant Application
Before the blanks feel the pressure, they’re run through a Unist SPR-2000 Sproller lubricant applicator, which applies a controlled layer of heavy-duty chlorinated draw lube (Prodraw 150, from Wallover Oil Co.) top and bottom.
Triple-Action Press Technology— Submitted by Thomas M. Lavoie, applications engineering manager, Greenerd Press & Machine Co., Inc.; www.greenerd.com Triple-action hydraulic presses feature several cylinders that can perform multiple operations during one setup, often the case when forming cookware as well as aerospace components and other products. The three actions include the main punch, cushion and blankholder platen. The presses can help to eliminate additional tooling requirements while enabling manufacturers to produce more uniform components, rather than having to manipulate the part several times with different tools. A triple-action press also provides complete control over the various ram movements. The ability to set and manipulate parameters will result in the most efficient cycle possible, for a better-finished part. Parameters can include draw speed, reverse tonnage on the cushion, and when to actuate an eject function. Depending on the application, the press can be custom-designed to meet specific requirements. Consider the examples below. 1) For some applications, including cookware, a triple-action press includes a main slide (where the tooling is mounted), a knockout/eject mounted on or above the main slide and a cushion/eject mounted below the press bed. This design proves useful for drawing a deep pan—the part draws over a punch but sticks in the upper tool when the main slide retracts. At that point, the knockout/eject can keep the part down on the punch or strip the part from the upper tool. Here, the cushion/eject is used primarily to provide pressure on the material so it can be drawn without wrinkling or tearing. By altering the press design and mounting the punch to the main slide, the cushion/eject will provide blankholding force during the downstroke of the main slide. The cushion/eject then would be used to push the part up and off of the lower tool or punch. 2) For other applications, a triple-action press includes a blankholder slide—which allows a higher-tonnage ram to run through the middle of the press—as well as a bed-mounted cushion/eject. The press can feature any combination of cylinders to provide power to form, punch, coin, draw, etc. in one setup, and finds use in the manufacture of jet-engine cowlings. The main slide serves as a blankholder platen, and applies adjustable tonnage to the material as the main ram (located in the middle of the main slide) descends to form the cowling. The cushion/eject can be used to push the part up and out of the lower tooling.
“We added the Unist systems in mid-2012,” says DeHosse, “to remove operator inconsistency from when applying lube manually. We experience more forming problems from too much lube, rather than not enough, because excess lube can get trapped between the blank and the blankholder. This can cause radial lube lines to form in the upper lip of the pan. We’ve completely eliminated that problem with the new lube systems.”
Why, Where and When
After deep drawing, parts travel by conveyor (part of the one-piece flow setup installed in 2010) to a hydraulic trim press, then on to CNC lathes for edge finishing. They then route to a washing system (supplied by Walsh Manufacturing), which in 2010 replaced three separate wash lines— “One more step in the process to implement single-piece flow,” shares DeHosse.
“We’ve decreased the time it takes to move blanks from the blanking cell to a final buffing operation,” continue DeHosse, “from 4 to 5 days when we were batch processing to as little as one shift.” MF
See also: Greenerd Press & Machine Co., Inc., FANUC America, Inc., Aida-America Corporation, A Subsidiary of AIDA Engng LLC, Unist, Inc.
Related Enterprise Zones: Automation, Lubrication, Presses
