Sheet Fanners Handle Heavy-Gauge Steel
April 1, 2010
Hi-Powr permanent-magnetic sheet fanners introduced by Eriez Manufacturing Co., Erie, PA, will successfully separate steel sheet as thick as 1⁄8 in. in stacks to 14 in. tall. Semi-sticky, oily and bent sheets can be fanned with ease thanks to a rugged magnetic circuit completely enclosed to withstand severe usage. Units—available in three strengths and four functional heights—feature a durable stainless-steel U-shaped frame with stainless-steel antifriction strips and back cover.
Eriez Manufacturing: 814/835-6000; www.eriez.com
Industry-Related Terms: Strips
See also: Eriez Manufacturing Co.
