Punch Tooling Upgraded for Extended Grind Life
December 1, 2009Comments Wilson Tool, White Bear Lake, MN, has upgraded its High Performance (HP) line of punch-press tooling by including its new HP2 spring packs and by enhancing its WB tool steel. HP2 spring packs enable fast, accurate punch-length adjustment in 0.005-in. increments without the use of tools or buttons. And, the enhanced WB tool steel ensures maximum grind life of punches.
Wilson Tool Intl: 800/328-9646; www.wilsontool.com
See also: Impax Tooling Solutions, A Div. of Wilson Tool International
Technologies: Tooling
There are no comments posted. Tooling
Manuel Resendes September 25, 2025
Engineering the Outcome: Tool Steel by Design, Not Default
Reading the Strip: The Story Behind Every Stroke
Manuel Resendes Monday, November 24, 2025
Introducing the MetalForming Tool & Die ebook
Wednesday, January 15, 2025
