Latest Generation of High-Performance Gas Springs
February 1, 2008![]() |
Hyson Products, Brecksville, OH, has issued literature on Tanker B (TNKB) nitrogen gas springs, which offer 25 to 35 percent more force than the The brochure details TNKB features including patented dynamic lubrication to reduce heat buildup and extend spring life; a bore seal to resist contamination and rod damage; and the corrosion-resistant nitrided rod, self-aligning to accept normal die movement and a degree of sideload without damaging the cylinder seal surface. The spring is offered in four sizes, in strokes to 7.87 in. It incorporates an SAE-4 port to accommodate standard full-size hoses, and has six flanges available for mounting. Hyson Products: 440/526-5900; www.hysonproducts.com
See also: HYSON Metal Forming Solutions
Technologies: Tooling
Preferred Automotive Components/Preferred Tool & Die Adds VP...
Wednesday, March 17, 2021
