Digital Sensor Reads Gas-Spring Pressure
August 21, 2020
Special Springs introduces the Eye, a battery-powered digital sensor that, when mounted on a gas spring, checks its pressure. A digital readout (in bars, psi or MPa) displays the actual pressure value and reveals immediately, by displaying a red light, if the pressure falls below the set value, reducing maintenance costs and increasing safety. Measuring capacity: 600 bar / 8700 psi / 60 MPa. Resolution: 1 bar, 10 psi, 1 MPa.
See also: Special Springs LLC
Technologies: Sensing/Electronics/IOT, Tooling
