Automated Nesting and Cutting-Path Generation Supports Laser Blanking
April 1, 2017
LaserCoil Technologies LLC, Napoleon, OH, has developed LaserCoil CAM to support its coil-fed laser-blanking systems, automating the importing of part profiles for optimized nesting and cutting. LaserCoil CAM accommodates single and multiple cutting heads, as well as peripheral automation such as the system’s dynamic conveyor lanes. In addition to optimizing part recipes, LaserCoil CAM also controls and monitors the blanking system during production.
“Creating nesting and cutting programs is a time-intensive process requiring a skilled technician,” says LaserCoil chief technology officer Jay Finn. “LaserCoil CAM takes only minutes from the importing of CAD files to active cutting of simple blanks. To illustrate its efficiency, imagine if you could design and machine a blanking die for a complex part in less than 30 min.”
LaserCoil CAM begins by creating a recipe with prebuilt initial cutting parameters supplemented with the blank’s profile data imported via a CAD file. The user can either ask the software to select the best coil from multiple coils in inventory, create the best nest for a specific coil width, or permit the program to specify the optimum coil width based on part yield.
Taking into consideration the appropriate grain constraint for material flow as well as part profile, the software identifies the best nesting pattern and then determines how the profiles will be cut by the laser. Next, the operator generates the cutting path; he can make adjustments by clicking on the profile parameters and setting a new cutting routine. The software then generates a simulation to illustrate the sequenced travel path of the cutting head.
“This software provides our customers with a single interface to help reduce programming time and scrap rates, as well as improve their throughput and yield,” notes Scott Sonnenberg, LaserCoil director of mechanical engineering/product development.
LaserCoil: www.lasercoil.com
Industry-Related Terms: Blanking, CAD, Cam, Die, LASER, Nesting, Scrap
See also: Lasercoil Technologies LLC
Technologies: Software
