[AD_TAKEOVER]
Double Valve Ideal for Small Control-Reliable Pneumatic Machines
October 1, 2013
Ross Controls
Booth S4221
Ross Controls, Troy, MI will showcase its DM2 Series D size 2 double valve for control of clutch/brake mechanisms. The 100-percent dynamically monitored valve has complete memory, is control-reliable and Category 4 rated for press applications. Its dirt-tolerant, wear-compensating poppet design provides quick response and high flow capacity. Use it on small gap-frame and die-cut presses, cylinder presses, small shears and on other small control-reliable pneumatic machines.
For Category 4 control-reliable operation of double-acting devices (including shear and cylinder applications), Ross offers its base-mounted Series 77 5/2 CrossMirror solenoid pilot-controlled double valves. Available in size 2, 4 and SAE size 4, the valves offer an optional pressure switch for external monitoring, providing for lockout in the event of a fault, and inhibiting further machine operation until the fault is corrected.
www.rosscontrols
See also: Ross Controls
