Adjustable-Angle Tooling Unit for the Pressroom
June 4, 2020Bilsing Automation has developed new swivel-unit tooling for
use in the pressroom, a flexible transfer-automation solution to address the
trend of reducing the number of operations in a press line by producing more
parts via a single stamping. While most tools can be used only at a specific
tilt angle, swivel transfer tooling provides a universal solution that can be
adjusted to the exact degree required to grip and handle parts for each
application. Additionally, compared to similar tools, the Bilsing unit
reportedly is 30 percent lighter.
The new tool provides a swivel angle of plus or minus 45 deg. (90 deg. max) and a compact design for optimum accessibility, even in difficult-to-reach, tight applications. Used as a single tooling unit, it weighs 8 lb.; with a connecting bridge used to create a double swivel unit with synchronous operation, total weight is 16.7 lb.
Holding force: 35 Nm. Optional features include sensors that automatically detect angle position, and a shutoff valve that locks the tilting-position angle during installation and removal to ensure operator safety.
See also: Bilsing Automation North America
Technologies: Pressroom Automation, Tooling
Destaco Updates its 800 Series Manual Clamps, Debuts Front-M...
Thursday, May 26, 2022
Multidirectional Forklift Ideal for Tight Spaces
Friday, March 11, 2022
