Mobile Pallet Wrapper Eliminates Hand Packaging
June 1, 2008Comments GaleWrap, Douglasville, GA, has introduced the GW-3500 mobile
The GW-3500 handles 70-ft.-diagonal loads, wraps 10 loads/hr. and runs at 11 rpm. Other features include manually adjustable film tension, up/down wrapping cycles, independent top and bottom wrap-pattern selection from one to nine wraps, and a splash-proof wrapping mode. The mobile pallet wrapper also eliminates load failures by securely wrapping each load. Its mobility allows for wrapping anywhere and its small footprint allows for simple storage.
GaleWrap: 770/900-6798; galewrap.com
See also: Yellow Jacket/ITW Muller
