Lifting Magnets Simplify Difficult Steel-Handling Operations
September 1, 2008Comments SafeHold APL-series lifting
SafeHold APL magnets are designed so that an operator is not required to manually release the magnet. They require no electricity, with no costly DC power supply nor a recharge. The magnets can be used singly or in multiples on a spreader beam. They come in three models to handle loads to 5800 lb.
Eriez: 814/835-6000; www.eriez.com
See also: Eriez Manufacturing Co.
