What Are Your Recommendations for Applying Coatings to Extend Tool Life?
August 5, 2024
Good question. As with any continuous-improvement effort, be careful when adding coatings. You may think nothing will change, but adding tool coatings can lead to unintended consequences.
The purpose of adding coatings or changing the base-tooling-material grade itself is to extend tool life. Extending the number of hits you can get from tooling during stamping, forming and camming reduces the time and cost required to service or replace the tooling.
Experimentation and development with different steels and coatings on new projects are straightforward. In the end, the winner is the combination with the longest service life and yielding the best quality. Once development completes, everything should proceed status quo. If, however, you try new coatings on existing production tooling as a continuous-improvement process, proceed with caution and use due diligence.
New tooling may be built with standard, uncoated steel for two reasons. First, in development, form and trim punches must be changed to achieve the required results, then groomed as needed to meet quality requirements. Special steels and carbide coatings can be three times more costly than standard tool steels—coating at this stage could be wasteful. Most likely, coatings will be removed during refacing as you make changes in development. In addition, during development you may need to manufacture new components quickly; coating costs and lead times may make this unfeasible.
After development is complete, the tooling usually moves to the repair and maintenance department. In any world-class manufacturing operation, this department oversees the long-term production and continuous-improvement processes. These processes should never end. They should include—but not be limited to—upgrading tool steels and applying coatings to improve tooling life. The purpose is to get away from putting out fires by fixing, sharpening and repairing in a reactive mode. Doing so results in unplanned tooling downtime.
Before trying out coatings on tooling, establish a baseline for the current production process by setting up process-control limits on data taken from key parameters before any changes have been made. Then monitor the data in real time to these control limits until it is stable and consistent. You cannot improve an unstable process.
Doing this serves three purposes:
  1. Ensures a stable process. You cannot improve a process you cannot control. It’s like trying to catch a dog by chasing its wagging tail.
  2. Identifies which uncoated tooling wear components to replace to ensure that quality requirements are met continuously.
  3. Establishes a baseline on the current, expected uncoated-tool life.
Changes to tooling base materials and coatings are subject to the same controls as all replacement tooling, including verification that components meet all of the dimensional requirements spelled out on the print. After replacing tooling components—with or without changes in base materials or coatings—standard good-manufacturing processes apply. The part-inspection data verify that the part dimensions have undergone no unassignable shifts. The maintenance cycle then repeats during production and continues for the life of the program.
While pursuing continuous improvement, remember tooling law No. 10: Grow and improve in steps. And, don’t forget tooling law No. 4: If nothing changes, nothing will change. Continuous improvement requires change, so you need to seek it. If you do not innovate, the competition will pass you by. Encourage every employee to be a leader in this process by being a proponent of change. Happy stamping. MF
Industry-Related Terms: Form, Forming, Forming
Technologies: Finishing, Lubrication, Materials
