Protective Wrap Keeps Rust at Bay
October 1, 2014Comments
Metal Rust Guard
Booth A2555
MetalRustGuard is a self-adhesive, nontoxic protective wrap that works in all environments to protect against rust and corrosion on all metals. It also can be used as a protective shield against abrasion during shipping.
The product starts off as a nonwoven polypropylene that is impregnated with a highly formulated wax. Together the components create a hydrophobic, strong and flexible wrap that conforms to military specifications.
It’s an im-penetrable barrier to outside conditions regardless of climate or moisture content, and replaces the need for expensive and ineffective VCI paper, film and bags. The material sticks directly to metal or can be used as a blanket to wrap around several parts. www.metalrustguard.com
See also: Metal Rust Guard
Technologies: Materials
There are no comments posted.Aluminum Sheet Alloys
Eren Billur Monday, October 27, 2025
New Packaging Film Prevents Corrosion, Discoloration on Meta...
Friday, February 12, 2021
Heating Helps Forming, Part 1: Hot Stamping of High-Strength...
Eren Billur Wednesday, July 29, 2020
