Portable, High-Speed Plasma-Cutting Power
September 1, 2008Comments Esab Welding & Cutting Products, Florence, SC, has launched two new models in its PowerCut line of
Like other PowerCut models, the new PowerCut 1300 and 1600 machines offer high-speed cutting and thickness capabilities as well as high duty cycles.
New is a tool-less quick-disconnect torch that disconnects from the machine without the use of wrenches or special tools, allowing simple disassembly for storage, repairs or replacement or to attach a mechanized torch for mechanized applications. A new digital-readout display is simple to read and shows the exact pressure or amperage. The display also shows help codes to assist in troubleshooting minor errors and minimize downtime.
The PowerCut 1300 cuts steel to 1.25 in. and severs to 1.5 in. The PowerCut 1600 cuts 1.5 in., and severs 1.75 in.
Esab Welding & Cutting Products: 843/669-4411; www.esabna.com
See also: ESAB Welding & Cutting
Technologies: Cutting
