CNC Plasma Cutting Streamlines Helical-Pile Fabrication
February 19, 2025Comments
Sealevel Construction, Inc., in Thibodaux, LA, has been serving the U.S. Gulf Coast region since 1997.
Sealevel Construction, Inc., in Thibodaux, LA, has been serving the U.S. Gulf Coast region since 1997. Initially a small public-works firm, Sealevel quickly grew into a turnkey, civil-construction company serving the municipal, industrial and marine markets, and employing more than 300 people.
Industrial division manager Tyler Glaze attributes the firm’s growth to its expansion into industrial facilities, where Sealevel performs site development, pours structural concrete and installs all types of deep foundations, including the fabrication and installation of helical-shaped steel piles.
After a few years of installing helical piles, company
management decided to begin manufacturing them inhouse. The team initially
experimented with manual production by cutting piles with a bandsaw or torch
and then drilling out the bolt holes, but that process caused bottlenecks.
Although making a square cut on one end of each pile was fairly
straightforward, miter cutting the opposite end proved more complex. And when
it came to drilling holes, dimensional tolerances were tight and difficult to
maintain manually.
“It took forever to lay the piles out, manually cut them and then weld the helical sections to the piles, because the cuts weren’t clean,” says Glaze.
Investing in CNC Pipe Profiling
Sealevel, refusing to sacrifice quality and delivery schedules, knew it needed to integrate CNC machinery into its fabrication process, leading it to explore CNC pipe-profiling technology. Its fabrication facility already had been operating a CNC plasma-cutting table and CNC beam processor, so the team was well aware of the value CNC could bring to its processes. A CNC pipe profiler not only could help with the helical piles, the team believed, but it also could support fabrication of the pile jackets—a sleeve used to protect the piles from ground movement—where complex copes, miters and bevels are common.
Soon after, Glaze opted to purchase a used CNC pipe-cutting machine, a ProCutter 600 from HGG Group rated for pipe to 24-in. dia., and which can cut a pipe in 30 sec. that would take two workers 45 min. to cut manually. Using the machine to cut pipes accurately and precisely the first time around, Sealevel fitters and welders were able to shift their focus to fitup and welding rather than on laying out, cutting and fixing mistakes.
