HVAC Sheetmetal Fabricator Adds 4-kW Laser-Cutting Machine
September 1, 2009M&M Manufacturing Co. has installed a Mazak Hypergear 2D FMS laser-cutting system at its Precision Products Division in Fort Worth, TX. The machine, from Mazak Optonics Corp., Elgin, IL, features a 4-kW laser to cut mild steel to 1 in. thick, as well as a material-storage tower for holding and retrieving as many as 10 different sheet specifications.
A pneumatic load system positions each sheet on the cutting table—with material loaded in the tower, the setup can run untended for complete shifts or over the weekend.
See also: Mazak Optonics Corporation
Technologies: Cutting
Mazak Optonics Showcases New 15-kW Laser Cutting Machine at ...
Wednesday, May 4, 2022
Tenere Opens New Sheet Metal Fabrication Plant in Nuevo León...
Tuesday, April 26, 2022
What Cutting Method Should I Choose?
Thursday, March 31, 2022
