After extensive discussions, Nahanni agreed, in 2013, to run some of its material on Coe equipment featuring the firm’s advanced HD-straightener head, at its Sterling Heights, MI, facility. “Crossbow correction has always been in the realm of leveler capability,” says Zupanec. “We viewed Coe’s ability to address coil set and crossbow on the same machine as a real accomplishment.”
To optimize slack-loop storage and maximize feed speed (the coil line can support press speed to 70 strokes/min.), the coil line employs lasers to track material location. |
Nahanni next laid out its requirement wish list, which included a solution that could run a broad range of materials, material thicknesses (0.030 to 0.300 in.), and increased material strengths; optimize floor space; and enable simple and safe threading.
“At that point,” Foster adds, “we focused on overcoming the technical hurdles of condensing a line that would normally stretch 45 to 50 ft. long and to less than 25 ft.” Building on a Good Foundation Starting with the capabilities of the advanced HD-straightener head, the Coe engineering team continued to design the rest of the solution from the ground up, developing several new concepts. Engineers verified design feasibility with solid modeling, unique spreadsheet calculations and finite-element analysis, ensuring that the machine would have the right structures in the right places. Ultimately, Nahanni Steel Products welcomed, in September 2015, a new coil line (Coe’s new SpaceMaster Series 4 compact coil line) that unwinds, straightens and feeds coil stock in yield strengths to 1000 MPa at speeds to 60-70 strokes/min, within 23 ft. of floor space. Key to the design is a unique approach to pilot release—the act of momentarily releasing the strip to allow it to be aligned by pilot pins in the die. This momentary release relieves built-up stress and binding of the strip through the feed and die, caused by feed-length variation, misalignment and coil camber. Most servo-driven roll feeds and feeder-straighteners feature air- or hydraulic-operated pilot-release mechanisms. Here, Coe provided what reportedly is the industry’s first servo-driven pilot-release mechanism, able to achieve higher speeds than conventional mechanisms. As explained by Coe director of engineering Jim Ward, “A servo motor rotates an eccentric mechanism to drive the pilot-release mechanism. This design allows us to achieve 60 to 70 strokes/min. with full pilot release.” The servo-driven feeder-straightener has 4-in.-dia. straightening rolls and 6.3-in.-dia. pinch rolls, selected for processing heavy-gauge and high-strength materials. The small straightener rollers provide a small radius around which to bend the material to accommodate AHSS, which needs to be bent more severely in order to exceed its high yield point. Adds Ward, “The straightener-head design has close centers to effectively yield thinner yet stronger material, as well as increased force delivery so a wider range of materials can be processed and flattened.” Another unique feature of the new line is a pivoting pull-off roll assembly. This allows tension to be maintained on the coil to prevent clock-springing, and it enables higher line speeds for the compact coil-line process. Additionally, the roll system is self-leveling to accommodate a wide range of material thicknesses. Proof is in the Performance Describing the benefits Nahanni has realized with its new coil line, Zupanec notes significantly reduced coil changeover time, improving efficiencies. Coil handling and safety also have been improved, he says, with reduced trial-and-error times to meet required specifications that had previously challenged the company. And, whereas press rate once exceeded feed-line capability, the new line promises to help improve throughput.
Technologies: Coil and Sheet Handling, Materials
There are no comments posted.Dallas Industries Delivers Feed Line to ODM Tool & Manufactu...
July 9, 2025
