Dallas Industries Delivers Feed Line to Precision Tool & Stamping
October 17, 2024Comments
Dallas Industries, a manufacturer of coil-handling, press-feeding equipment and controls, has supplied a conventional feed line to Precision Tool & Stamping, Inc., Clinton, NC. The 42-in.-wide conventional line features a 10,000-lb. capacity uncoiler with coil restrictor and load car, a model DPS- 3.0- 7- 42 powered straightener with Hi-Torque backups and an alligator peeler/theader, an ETT-42 thread table, and a model DRFM-442 cabinet-mounted servo roll feed.
The line is built on an Allen-Bradley Ethernet-based control architecture and features Dallas’ SyncLoop and ProfileSelect technologies. The SyncLoop control synchronizes feeder and straightener speeds to enhance loop stability and control; the ProfileSelect feed control uses a cam-motion (sinusoidal) profile that utilizes 100% of the press-feed window, reducing stress on the material and the feed’s mechanical components.
See also: Dallas Industries
There are no comments posted.Press-Line Controls Under One Umbrella-An Ideal Solution
Lou Kren September 27, 2024
