Toledo Tool & Die Purchases Two Dallas Feed Lines
September 25, 2020
The compact and flexible Loop Select SpaceSaver feed lines feature a selectable loop control. The front-loop mode allows processing of light-gauge material at long feed lengths and higher speeds, while the back-loop mode allows processing of heavy-gauge materials using a clock-spring loop to form beneath the coil. Included is Dallas’ SyncLoop technology to monitor average line speed and loop depths and automatically adjust payout speeds to ensure a smooth payout; and ProfileSelect, a unique feed-control system that employs a sinusoidal (cam-motion) profile to result in a smooth feed motion utilizing 100 percent of the press-feed window, reducing stress on the material and the feed’s mechanical components.
See also: Dallas Industries
Coe Debuts Combination Straightener-Reel for Light-Duty Appl...
February 11, 2021
