La-Z-Boy Takes Delivery of Feed Lines from Dallas Industries
February 1, 2018Dallas Industries, Troy, MI, a manufacturer of coil-handling, press-feeding equipment and controls for the stamping industry, has announced that the La-Z-Boy facility in Neosho, MO, has taken delivery on two feed lines. One line is a 36-in.-wide conventional line featuring a model DRF-536 cabinet mounted servo-feed, threading table, model DPS-3.5-36-7 powered straightener and a 20,000-lb.-load-capacity reel with load car. The second line is an 18-in.-wide conventional feed line featuring La-Z-Boy’s existing model DRF-418 cabinet-mounted servo feed (with a new controls retrofit), threading table, model DPS-3-18-7 powered straightener and a 6000-lb.-load-capacity reel.
Both lines were built on an Allen-Bradley, Ethernet-based control architecture and feature SyncLoop and ProfileSelect. SyncLoop controls synchronize the feeder and straightener speeds to enhance the slack loop’s stability and control. ProfileSelect is a unique feed-control system and a Dallas Industries exclusive. It uses a cam-motion (sinusoidal) profile for a feed motion that utilizes 100 percent of the press-feed window, reducing stress on the material and the feed’s mechanical components.
See also: Dallas Industries
Coe Press Equipment Hires Regional Sales Manager for Mexico ...
Tuesday, May 24, 2022
Automatic Feed Appoints Eric Sonnenberg as Service Manager
Tuesday, May 10, 2022
Coe Ships Feed Line to TRA Snow & Sun
Monday, May 2, 2022
Coe Adds Regional Service Technicians
Friday, April 29, 2022
