Vacuum Lifter for Coil Handling
February 1, 2011Comments
An air-powered, below-the-hook vacuum lifter, designed specifically for lifting sheetmetal coils to 4-ft. dia., has been introduced by Anver Corp., Hudson, MA. The Anver VPFL-4 vacuum lifter has an X-style frame with adjustable suction pads and spring suspension. Featuring a circular perimeter guard for added protection, the lifter provides continuous vacuum to the suction pads and has an adjustable handle with integrated controls.
Designed for safety, the unit also is equipped with a VLS-8 vacuum leakage sensor, powered independently by a 9-v lithium battery, which sets itself to the vacuum system’s peak vacuum level and displays it on an LCD in front of the operator. If a 10-percent or greater vacuum loss or leakage occurs, the sensor triggers a loud horn and signals the LED warning light to begin to flash.
Anver Corp.: 800/654-3500; www.anver.com
See also: Anver Corp.
Coil and Sheet HandlingElectric Dodge Charger Production at Stellantis-Windsor Plan...
Tuesday, December 17, 2024
VideoDallas Industries Delivers Feed Line to Precision Tool & Sta...
Thursday, October 17, 2024
24-In.-Wide Press-Feed Line on Display
Thursday, July 25, 2024
Canadian Stamper Orders Automatic Feed CTL Line
Monday, January 9, 2023
