Primer Provides Extended Corrosion Protection
December 1, 2018Comments
A patented polyurethane primer, Spectracron AdvantEdge HPP, from PPG, can be used in heavy-duty equipment, general finishing and transportation applications. It provides extended corrosion protection, enhanced performance on sharp laser-cut edges, and superior chip resistance, according to company officials.
Formulated without heavy metals, the primer provides a more sustainable solution for achieving superior corrosion resistance and sharp-edge performance. A wide application window, compatibility with common topcoat hardeners and shorter wet-on-wet application times enable applicators to increase process efficiency.
It works with an array of pretreatment systems and delivers corrosion protection on many different substrates, helping to ensure consistent end-product quality despite variation in surfaces and surface prep.
See also: PPG Industries
Technologies: Finishing
There are no comments posted.Daubert Cromwell Appoints Rodrigo Martinez Mexico Country Le...
Monday, March 18, 2024
MicroCare Welcomes Lu Anne Green as Chief Operating Officer ...
Monday, January 15, 2024
Chemcoaters Introduces Corrosion-Inhibiting Coil-Coating for...
Friday, May 12, 2023
Weldable Rust Inhibitor
Thursday, October 20, 2022
