Hot off the Press
Bangladesh to Gain Pole-Manufacturing Plant
Wednesday, October 31, 2018
Hydrapower International, Inc., with world headquarters in Marco Island, FL, has won a contract with Cygni Engineering Ltd. of Dhaka, Bangladesh, to supply a utility-pole manufacturing plant. Which will include an advanced coil-processing line with integrated taper slitter, tandem 1100-ton x 25-ft. press brakes with quick-change pole tooling and automated front-material-positioning system. Hydrapower projects 100 poles per shift, using eight workers.
YOUR NAME *
EMAIL *
WEBSITE
