Magnetic Clamping Puts Die Change Delays Out to Pasture
By: Brad Kuvin
Wednesday, March 1, 2017
The CNH plant in New Holland, PA, manufactures, among other farm equipment, these round balers. The plant’s deeply rooted in a World Class Manufacturing system aimed at eliminating waste and loss by focusing efforts to achieve zero defects, breakdowns and waste.
The cushion between the metalforming and fabricating shop and assembly lines at the sprawling New Holland (PA) Agriculture plant of CNH Industrial is a scant single day. In short, the shop stamps and fabricates parts when they’re needed on the lines, where the firm’s balers, mower-conditioners, harvesters and other farm equipment come to life.
Reduced inventories is just one tenet of the CNH World Class Manufacturing (WCM) system, with tentacles reaching into total quality control, total productive maintenance and just in time. As explained by manufacturing engineer Corey Messner, WCM initiatives aim to prevent waste and loss by zeroing in on achieving zero defects and breakdowns, and—most noticeable in the plant’s pressroom—minimizing press-setup times to boost equipment OEE and ensure punctual part delivery to the assembly lines.
Better Die Changes Help with Kitting
“Recently, our shop has been implementing a kitting process to supply a small internal warehouse from which the assembly lines pull parts and subassemblies as needed,” says Messner. Those activities have helped the company shrink lot sizes, which of course means more die changes in the shop.
“On our hand-fed presses,” Messner says, “we’re running lots of only 50 to 100 parts. On our coil-fed press, lot size peaks at around 10,000 parts. We’re changing dies as often as 10 times/shift on each press, so any improvement in our die-change process has a significant ripple effect on pressroom productivity.”
The plant’s pressroom houses six mechanical stamping presses, ranging from 165 to 400 tons. All but one are hand fed with blanks—some laser-cut on the firm’s laser-cutting machine. The one coil-fed press is the plant’s newest, an Aida 200-metric-ton servo press (84- by 33-in. bed) acquired in 2014. It’s a workhorse, tasked with running some 80 different dies, half of which run at least once per month. And, the press often tackles the plant’s most challenging parts.
The servo press came equipped with the latest in quick-die-change technology: a permanent-electromagnetic-die-clamping system (a Stamp Tec setup from Tecnomagnete).
“The servo press replaced a 33-yr.-old coil-fed press,” Messner says, “and now gives us improved ram-speed control that helps with our more challenging jobs, such as drawing thin-gauge material. We added the magnetic die-change system to the press to further optimize its capabilities and free up as much production time as possible, so we could move work over from other presses.”
One of six stamping presses supplying stamped parts to CNH assembly lines is this 200-metric-ton Aida servo press, equipped with a Tecnomagnete magnetic die-clamping system. Green lights on the system’s control panel (top right) indicate proper clamping. Here, the servo press forms bearing housings from 0.157-in.-thick hot-rolled Type A1011 steel at 53 strokes/min.
The WCM agenda calls for single-minute exchange of dies (SMED), the Japanese-born lean concept calling for production-changeover times measured in the single digits (less than 10 min.) Messner notes that the pressroom is right there.
“We’re getting dies in and out of the servo press in about 10 min., with last-part to first-part times in the range of 20 to 30 min.,” he says. “This is a 50-percent improvement for every changeover, which has had a huge impact on productivity.”
More on Magnetic Clamping
The Tecnomagnete Stamp Tec setup is a round-pole bi-mag clamping system that, says company literature, “eliminates the resin previously used in all square-pole products.” Magnet clusters, says Messner, are embedded in 2-in.-thick steel plates that bolt to the press ram and bolster. (The shop tested the system on the ram plate of another press, a 165-ton standard mechanical press, before installing it on the ram and bolster of the servo press).
During a die change, proximity sensors on the top and bottom magnetic plates sense when the die is in proper position. The operator then initiates the ram to come down to touch the top die half, turns a key and presses a button on the control panel to activate the magnets and secure the die sections. All of this control is integrated into the press control—any interruption in the magnetic circuit automatically shuts the press down.”
The magnetic setup, Messner explains, is a universal process that easily adapts to the shop’s dies. Dies are changed using a fork truck; a dedicated die cart maneuvers larger dies around the pressroom.
Helping orient the dies in the press are locating plates installed on the bottom die half, to corner the die on the press bed. “This helps to standardize the die-change process,” Messner explains, “and helps our technicians get in and out of the press as quickly as possible.”
Accommodating Gas Springs
Another task the shop had to complete to accommodate the die-change system: adding nitrogen-gas springs to about 20 of the dies that run in the servo press.
“A lot of our dies were using the air cushion in the older press,” Messner adds. “With the magnetic bolster plate, we had to change those dies over to gas springs. Then, we had to be sure to account for the added die height with the press.” MF
See also: Aida-America Corporation, A Subsidiary of AIDA Engng LLC
Related Enterprise Zones: Automation, Presses, Tool & Die
