Continuous-Coil Fiber-Laser Cutting
Sunday, June 1, 2014
Continuous-coil fiber-laser cutting Dimeco Alipresse, a French manufacturer of press-feed lines, introduces Linacut coil-fed laser-cutting lines for processing material 0.3 to 4 mm thick. The lines include a 5-ton decoiler, coil-loading car, precision straightener, threading table, 2-kW fiber laser, roll feeder, seven-axis gantry robot and stacking table.
Dimeco Alipresse: www.dimeco-alipresse.com
See also: Dimeco Alipresse
Related Enterprise Zones: Coil Handling, Fabrication
