Hot off the Press
Feed Lease Feeds Two More Lines
to Fayette Tool and Engineering
Friday, July 25, 2003
Fayette Tool and Engineering, Inc., Connersville, IN, recently took delivery of two Feed Lease Corp. (Rochester Hills, MI) coil-feeding lines, bringing the number of Feed Lease-supplied lines at Fayette to six. The two new identical lines each consist of a servo roll feed with a pull-through five-roll straightener, which reduces the space normally required for powered straighteners. The servo feed features crodon-surfaced feed rolls, sealed-for-life double-row ball bearings and dual pneumatic cylinders for roll lift and pilot release. The feeder mounts on an adjustable-height cabinet with a four-roll curve section, remote jog pendant and adjustable edge guides. The 10,000-lb.-capacity powered coil reel is includes hydraulic expansion, ultrasonic loop control and optional full-radius mandrel caps for use with lighter-gauge materials. For more on Feed Lease coil-feed products, visit www.feedlease.com.
