Plasma Cutting Leads Loveman
“About 30 years ago, we evolved to focus equally on the service center as well as fabrication,” explains Robert Loveman, executive vice president of Loveman Steel and representing the fourth generation of the family-owned business started by his great-grandfather David.
Growing its service-center business and finding itself producing more and more parts for its steel suppliers, company management decided to focus on ramping up its capabilities as a job-shop fabricator. Today, Loveman Steel, ISO 9001-2008-certified with its 85,000 sq. ft. of manufacturing space spread across 3.5 acres, calls Bedford Heights, a Cleveland suburb, home. Here it has developed a couple of niches: taking on large and/or difficult projects that others won’t touch, and providing annealing-hardware fabrications for mills.
Plasma Cutting to the Rescue
To succeed in these sectors, the company has relied in large part on plasma-arc cutting (PAC). Two PAC machines dot the Loveman work bays, sharing space with oxyfuel-cutting tables and other fabrication and welding equipment. Loveman’s 65 employees primarily work one shift for service-center operations, while fabrication functions across two.
The plasma unit, using HyDefinition technology to align and focus the plasma arc, delivers numerous benefits, according to Hypertherm officials, including improved arc stability, narrow kerf width to enable fine feature cutting and minimize material waste, dross-free cutting to minimize part cleanup, and repeatable cut-edge quality.
Also at Loveman, a recently retrofitted 600-A PAC water table, 156 in. wide by 552 in. long, cuts stainless and carbon steel to 2 in. thick. This table boasts a recently retrofitted Burny 10 control system from Lincoln Electric (Cleveland, OH), replacing outdated, unsupported controls. The retrofit also included a new Esab (Florence, SC) torch lifter and torch-lifter controls.
Speed, Quality Key in Fabrication Work
With its tables humming and backed by various other forming and joining equipment, Loveman churns out a diverse collection of fabrications. Its PAC capabilities have brought the speed, flexibility and accuracy necessary to turn these jobs at a profit while satisfying strict customer quality and precision requirements.
“If we had to rely on oxyfuel cutting instead of plasma, we couldn’t compete on many of these jobs,” explains Loveman’s Rob Campbell, maintenance supervisor.
Slicing through 0.375-in.-thick carbon steel at an average of 150-200 in./min (about 90 in./min. for thicker material), the plasma-cutting tables work fast, whereas oxyfuel often limits out at about 10 in./min. In addition, Loveman works plenty with stainless steel, and oxyfuel is no option there.
Convector plates used in the steel industry serve as one example of challenging work undertaken by Loveman made possible through the use of plasma-cutting technology. Loveman Steel will receive emergency calls from mill customers at any hour to fabricate one-offs to replace broken process-equipment pieces, large and small.
Plasma-cutting tables cut the plates and ribs, and also cut plate holes and notches in a swirl pattern (the ribs are cut in a curved pattern to match the arc of the plate patterns). The intricate work would eat up too much time if cut via oxyfuel, so PAC gets the call.
Plasma-cutting speed is huge at Loveman, where the company will receive emergency calls from mill customers at any hour to fabricate one-offs to replace broken process-equipment pieces.
Specialist in Emergency Work
“A steel mill with a busted ladle part is not producing steel and must be back online quickly,” explains Loveman. “With our workers and the equipment inhouse, we can turn around these orders, so customers keep coming back to us.”
Indeed, the list of Loveman’s recent and repeat customers reads like a Who’s Who. Within the past five years, the company has completed projects for U.S. Steel, Severstal N.A., AK Steel, Sun Coke, Allegheny Technologies, Nucor, Metso Minerals, Mitsubishi-Hitachi, North American Stainless and Arcelor Mittal.Beyond its clients in the material-producing and finishing industries, Loveman serves the power-generation, material-handling, petrochemical, aerospace and transportation industries. All of these industries employ unique pieces of equipment that operate under the harshest conditions, and it’s only a matter of time before a breakdown occurs.
Loveman has demonstrated to these customers that it can handle whatever may come its way, and deliver as promised. Sometimes that requires extra elbow grease, especially on larger parts. One recent project, recalls Loveman, necessitated fabricating a large 100-ft.-dia. assembly in 24 pieces, trial-assembling and truing it outdoors to ensure proper fitup, and disassembly into 24 pieces for delivery by truck to the customer.
But that’s all in a day’s work at Loveman Steel, where unique solutions are married to unique challenges. MF
See also: Hypertherm, Inc., Loveman Steel Corp, ESAB Welding & Cutting
