New 15-mm-Dia. Gas Spring Provides Up to 154 lb. on Contact
May 1, 2010CommentsNew from Dadco, Plymouth, MI, is the Micro 70 nitrogen gas spring, available in stroke lengths from 7 to 125 mm and with a 15-mm-dia. body and 7-mm-dia. rod. The spring provides force as high as 154 lb. on contact. It is the newest addition to the firm’s Micro Series, which includes Micro 45 (12-mm dia.), Micro 90 (19-mm dia.), Micro 180 (25-mm dia.) and Micro 250 (32-mm dia.)
Dadco: 800/323-2687; www.dadco.net
Technologies: Tooling
