Ball-Bearing Assemblies Mount Directly to Die and Punch Holders
July 1, 2009
Anchor Danly, Farmington Hills, MI, introduces a low-cost surface-mount ball-bearing component assembly that mounts directly to the die and punch holders, rather than the conventional method, as an alternative to its die-components guiding system product line. The assemblies come in 32-, 38-, 50- and 60-mm dia., with length from 100 to 350 mm. Complete assemblies include mounting bolts and dowel pins; tapped mounting holes, to secure stroke end blocks, are optional.
Anchor Danly: 440/239-7600; www.anchordanly.com
Industry-Related Terms: Die, Stroke
See also: DAYTON Lamina Corporation
Technologies: Tooling
