Fourth-Generation Robots Faster and More Flexible Than Ever
February 1, 2011Comments ABB Robotics, Auburn Hills, MI, introduces the IRB 2600, the latest model in its medium-capacity range of
Features include flexible mounting to enable optimized cell designs. Mount the robot on the floor, wall, inverted or on a shelf, helping to reduce floorspace requirements. Featuring a total arm weight of less than 300 kg and reportedly occupying less floor space than other robots in its class, working range is optimized—the arm can easily reach down below its own base, allowing for smaller production cells and furthering the efficient use of valuable manufacturing space.
Path accuracy and positional precision enhance flexibility and allow the IRB 2600 to be both a machine-tending robot and a process-validation robot.
ABB Robotics: 248/391 9000; www.abb.com/robotics
See also: ABB Robotics
