Examining the Secrets of Shaping Sheetmetal
June 1, 2017
Few people understand well the process used to fabricate two-piece (body and tear-top) beverage cans. For example, the two-piece can may begin as a blank of Type DR-9 steel that has been cold-rolled, annealed, and then again cold-rolled 35 percent and used without further annealing–producing sheets with full-hard status.
Fig. 1—Rollforming and bending of martensitic steel can have unexpected results. AHSS Application Guidelines—Ver. 4.1.
The rollforming process, used to initially harden the workpiece material, comprises a series of bending operations that start at the center of the blank and work outward. This allows early forming of the edge material to lock the sheetmetal, creating a stretch contribution. One benefit: The designed blank width is the sum of the neutral-axis widths. Therefore, the amount of material needed to form a complex design can be computed early in the deformation process.
To illustrate this, we rollformed sheets of martensitic steel (MS 1050/1400) to their smallest radius (Fig. 1). The same MS steel also was bent to its smallest radius; rollforming generated the smallest radius.
Forming the Can Body
Transforming the rollformed hard-steel blank into a usable can body then requires a five-stage process (Fig. 2).
 Fig. 2—Hardened steel blanks undergo a five-stage process to form a usable can body.
Stage 1—Draw: The flat blank is converted to a circular cup (shown at the left of the arrow in Fig. 2). This creates a starting point that can be reworked into many configurations.
Stage 2—Redraw: At stage 1 the cup has a dimension that is too wide and too short. A redraw operation forces a correct diameter by using a punch and die of smaller diameter.
Stage 3—Wall ironing: To utilize the excess thickness of the can body, a die is constructed to thin the walls of the can in a process that will cause an increase in can height. The example in Fig.2 has a die with three different thicknesses. As the punch drives the cup through the die, the cup wall becomes thinner and longer. This process allows the metalformer to adjust wall thickness and cup height as needed.
Stage 4—Bottom doming: Not all deep-drawn cups have flat bottoms. Some have hemispherical or otherwise configured bottoms—pushed inward or outward, for example. The forming process then turns from a material-independent cup-draw operation into a complex operation where the hemisphere is stretch-formed—highly dependent on material properties. The interaction between the drawn cup and hemisphere is not additive but interactive; add a stretch-form area to a simple cup draw and you create additional problems.
Beverage Containers Need Tops
Fig. 3—Beverage-can tops undergo a four-stage process that avoids air cracks when the pull tab is attached.
Fig. 4—Placing a stretch component on the bottom of a deep-drawn can may create a major problem.
State-of-the-art beverage containers feature anti-leak tops without any soldering or other hole-closing process required (Fig. 3). The four-step process to create the tops:
1) The flat-top blank is embossed in the middle of the top. This creates a round surface where objects can be hung.
2) The next step is a redraw that makes the embossment longer and narrower.
3) A spacer is placed over the embossment, followed by the pull tab.
4) Finally, the tab is crushed by the embossment with no leaks.
Combining Stretch and Draw
Working with stretch and draw presents thoughts of fun and play. Unfortunately, such projects can be exceptionally frustrating (Fig. 4). First, the stretch and draw zones are separated by the shock line—rarely is this line at the joint where the stretch radius joins the forming cup. The unbalance of strain often depends on the current problem. Not all deep-drawn cups have flat bottoms; some have other configurations.
To illustrate the problem, Professor Donald Eary (General Motors Institute, 1985) studied the stretch/draw and shock-line problem. To define the needed corrective actions, he developed a chart containing some 30 forming variables. The chart recommended a corrective action based on the type of forming issue and the forming variable. For example, if you had a problem with binder force during a stretch operation where the sheetmetal was moving in the flange, the chart suggested the draw solution to prevent wrinkles in the flange. MF
Industry-Related Terms: Annealed, Bending, Blank, Center, Die, Dimension, Draw, Edge, Flange, Form, Forming, Surface, Thickness
Technologies: Materials, Other Processes
