Weld-Cleaning Brush
February 1, 2011
weld-Cleaning Brush
Weiler Corp., Cresco, PA, has added a new 4.5-in. Roughneck to its line of high-performance stringer-bead brushes, designed specifically for use on 4.5-in. mini-grinders. Traditionally, welders and fabricators using 4.5-in.angle grinders have been limited to 4-in.-dia. stringer-bead wheels for surface preparation, root-pass weld cleaning and interpass weld cleaning. This new Roughneck brush is designed for optimum cleaning action and product life on small angle grinders, and features a high knot count and short trim length. The design reportedly results in a 35-percent improvement in cleaning action, as much as 20 percent less wire loss and a 50-percent boost in brush life compared to a 4-in. stringer- bead brush.
The new Roughneck is available with carbon-steel or Type 302 stainless-steel wire, with a variety of arbor-hole options.
Industry-Related Terms: Surface
See also: Weiler Corporation
Technologies: Finishing
