Next-Generation Right-Angle Grinding Wheels
October 1, 2013 Norton Abrasives
Booth N461
Norton Abrasives, Worcester, MA, unveils a major upgrade to its best-quality depressed-center wheels for right angle grinding applications. Norton NorZon Plus wheels now utilize a proprietary blend of the firm’s newest-generation SG ceramic-alumina and BlueFireT zirconia-alumina abrasives, combined with a new high performance bond system for significantly improved grain microfracturing. The NorZon Plus line also has been expanded with the introduction of NorZon Plus Fast Cut depressed-center wheels, designed for optimum material-removal rates.
The improved microfracturing capability of NorZon Plus provides a continual supply of serrated cutting edges, enabling unparalleled productivity, wheel life and overall cost effectiveness across a broad spectrum of right-angle grinding applications. NorZon Plus Fast Cut provides a 15- to 30-percent increase in cut rate compared to standard NorZon Plus wheels, say company officials. The wheels are available from 4- to 9-in. dia., ¼ in. thick.
See also: Norton Abrasives
Technologies: Finishing
Long-Lasting Nonwoven Flap Discs Deliver Quick Cutting, Fine...
Friday, December 9, 2022
CS Unitec Names Mike Sullivan Executive Vice President
Friday, August 19, 2022
New Program Helps Determine Solutions to Grinding and Finish...
Tuesday, April 19, 2022
