High-Speed Handheld Tube Beveller
June 1, 2008The Millhog beveler includes a pilot that automatically seats in the tube ID, and a cutterhead with field-replaceable carbide blade inserts and multiple cutting edges to perform 37.5-deg. end preps. It can bevel a single tube in 3 sec. and can be supplied with an optional track-mount system for rapidly end-prepping full panel sections.
Providing torque-free operation without cutting oils, the Millhog is ideal for repetitive end preps. Straight-through and right-angle models operating at 5000 or 10,000 rpm are offered with working ranges from 0.45-in. ID to 4-in. OD.
Esco Tool: 508/359-4311; escotool.com
See also: Esco Tool
Technologies: Fabrication, Finishing
New Program Helps Determine Solutions to Grinding and Finish...
Tuesday, April 19, 2022
