Sheet-Cutting Systems and Software
October 1, 2018Comments
Hypertherm
Booth B6351, C12542
Hypertherm will unveil two new cutting systems, two new software offerings and more. Debuting are a new X-Definition-class plasma-cutting machine along with a HyPrecision waterjet pump with advanced predictive-maintenance capabilities. In addition to its new systems, the company showcases new versions of its ProNest and Robotmaster software, and an extensive lineup of specialty torches and consumables.
The X-Definition-class machine combines engineering advances and refined high-definition plasma processes to deliver high cut quality on mild and stainless steel, and aluminum. The HyPrecision waterjet pump includes technology designed to provide warning of upcoming maintenance needs. Hypertherm will have cut samples from both cutting processes available at FABTECH.
ProNest 2019 is a major-version update of Hypertherm’s CAD/CAM nesting software for automated cutting. This release contains more than a dozen new features and enhancements. The new version of Robotmaster, v7, introduces a completely new architecture to the task-based robot-programming platform. It uses integrated CAD/CAM functionality that allows welding, cutting, painting, sanding and other process professionals to program industrial robots without having to buy or learn complex CAD/CAM software.
In addition, Hypertherm will present its Powermax line of air-plasma-cutting and -gouging systems, along with its lineup of specialty torches and consumables, in the show’s Welding Hall, at Booth C12542.
There are no comments posted.Robotic Plasma Coping for Structural-Steel Fabrication
Wednesday, July 9, 2025
