Five-Axis Laser Cutting
October 1, 2019 BLM Group demonstrates the LT-Free five-axis laser-cutting system for cutting bent and hydroformed tubes, flat and deep-drawn sheets and welded assemblies. With laser power to 3 kW, table dimensions of 1500 by 1000 mm, and axis stroke to X=2950 mm, Y=950 mm, Z=750 mm, C=continuous, B=140 deg, it’s ideal for machining a variety of materials. Included is CAD/CAM software to create part programs in a simple 3D graphical environment.
Specify the machine in a variety of material-handling configurations:
- Entry level—Two fixed workpiece tables for batch processing of bent tubes, hydroformed parts, and stamped and flat sheet.
- Mid flex—Equipped with dual shuttle tables that automatically shift in and out of the laser work zone, enabling load/unload simultaneous to laser processing and uninterrupted production.
- One flex—The fixed table and robot make this version ideal for processing large pieces for low-volume, high-mix production.
- High flex—A dual-robot configuration coupled with dual shuttle tables, also enabling loading and unloading without interrupting the cutting process.
- Piece value—A large rotary indexing table offers efficient and continuous production.
See also: BLM Group USA
Technologies: Cutting, Pressroom Automation
Mazak Optonics Showcases New 15-kW Laser Cutting Machine at ...
Wednesday, May 4, 2022
Tenere Opens New Sheet Metal Fabrication Plant in Nuevo León...
Tuesday, April 26, 2022
What Cutting Method Should I Choose?
Thursday, March 31, 2022
