20-kW Laser Cutting Machine Boasts 9-Sec. Pallet Changes
July 25, 2024Comments
BLM Group
Booth S22061
BLM Group demonstrates its LS7 laser cutting system, newly available with 20 kW of laser power to enable high-quality cutting at higher speeds and increased productivity. The LS7 has an axis acceleration to 2g, optimizing processing cycles and minimizing downtime, while the fully electric 9-sec. pallet change can increase productivity by as much as 9%. As the material handling is fully electric, the LS7 also provides improved maintenance and energy usage.
Equipped with the company’s patented Active Tools, which automatically adapt process parameters for optimal results independent of operator experience, the LS7 delivers precision and speed. Additionally, an active nozzle changing feature automatically monitors the wear of the cutting nozzle and exchanges it based on the condition set within the controller.
The LS7 comes in two sizes: model 3015 with a maximum sheet size of 121.5 by 62 in., and the 4020, for sheet sizes to 162.5 by 79.5 in.
Other equipment being demonstrated: an LT7 laser tube with robotic load/unload; LS5 sheet laser with automated load/unload; Elect, E-Turn and Smart tube benders; and ProBend press brakes.
See also: BLM Group USA
Technologies: Cutting
