Laser-Based Measurement System Ensures Flatness from Leveler Herr-Voss Stamco
September 1, 2008![]() |
In operation, the measurement system displays the optimum leveler backup settings necessary to correct the strip-shape defects. These settings can be adjusted manually, or with the push of a button the backup position can be automatically adjusted. www.herr-voss.com
See also: Herr-Voss Stamco
Monday, February 7, 2022
Automatic Feed Debuts New Coil-Feed Lines, and the Edge Stac...
Automatic Feed Debuts Coil-Feed Lines for High-Strength Stee...
Servo Feed Line Featured, with Automated Straightener Setup
Friday, July 16, 2021
