Heavy-Gauge Straightener for Stamping Thick Vehicle Components
February 20, 2020 Automatic Feed Company (AFCO), Napoleon, OH, introduces a new heavy-gauge straighteners designed for processing steel to ½-in. thick, and beyond. The robust construction and capacity of the machine makes suits it for manufacturing components for truck and automotive frames, wheels and other heavy vehicle assemblies.
With a bridge load of 1.2 million lb., the straighteners can process coiled-steel coils to 78 in. wide at speeds up to 150 ft./min. They feature nine work rolls—four upper and five lower, 6.75-in. dia. for precision material flattening. All rolls are driven through a common gearbox with multiple output shafts. This design feature helps to prevent material slippage and related material-quality problems.
A kicker roll, located after the work rolls, assists with removing upturn from reverse-wrapped coils. The kicker roll proves beneficial when processing these products because upturn tends to be more prevalent in heavy-gauge materials. The addition of kicker rolls can ease coil threading.Both the entry and exit sides of the straightener feature an independent pinch-roll unit, individually driven by a 75-hp AC servo motor. The 12-in.-dia. pinch rolls open and close with near- and far-side hydraulically actuated cylinders. These cylinders have proportional pressure-regulating valves, programmable as part of the part recipe. The entry and exit pinch rolls are separately driven and electronically speed-matched with the straightener work rolls.
See also: Automatic Feed Company
Canadian Stamper Orders Automatic Feed CTL Line
Monday, January 9, 2023
Automatic Feed Receives 3rd Leveler Order from Canadian Meta...
Monday, October 31, 2022
Arku Named Supplier of the Year by Kirchhoff Automotive
Monday, July 11, 2022
Automatic Feed Debuts New Coil-Feed Lines, and the Edge Stac...
Monday, February 7, 2022
