Gestamp Installs Compact Coil Lines in Brazil
April 1, 2012CommentsCoe Press Equipment, Sterling Heights, MI, has shipped two SpaceMaster Series 2 coil lines to Gestamp Parana S/A, to be installed on 600-ton Jier presses for stamping automotive parts. The lines are rated for material to 1⁄8 in. thick and 48 in. wide, and can feed at 60 ft./min. Each includes a combination feeder-straightener driven by Coe’s new ServoMaster Touch control.
