Arku Leveler Headed to Mayville
April 1, 2013To reduce scrap resulting from uneven sheetmetal parts that caused welding and forming problems, Mayville Engineering Co., Mayville, WI, has purchased a FlatMaster 55 precision leveler from Arku Coil Systems Inc., Cincinnati, OH. The leveler is rated for material to ½ in. thick. Mayville Engineering performs sheetmetal and plate cutting, forming, stamping, machining, welding and assembly.
See also: ARKU, Inc.
Canadian Stamper Orders Automatic Feed CTL Line
Monday, January 9, 2023
Monday, October 31, 2022
Automatic Feed Receives 3rd Leveler Order from Canadian Meta...
Arku Named Supplier of the Year by Kirchhoff Automotive
Monday, July 11, 2022
Automatic Feed Debuts New Coil-Feed Lines, and the Edge Stac...
Monday, February 7, 2022
