Support for Coil Feed
March 1, 2008![]() |
Bennett Tool & Die Co., Nashville, TN, will exhibit its CoilBridge conveyor that supports coil stock being fed into a die. The conveyor spans the long gap between press feeder and die entry, eliminating the need for makeshift supports to prevent the stock from sagging and buckling. The coil is continuously supported from feeder to die via heavy-duty precision bearing rollers made from either plastic or steel. The die-end support is adjustable through the use of a hand crank and pivoting brackets along with a jack to provide perfect alignment.
See also: CoilBridge Conveyor
Automatic Feed Appoints Eric Sonnenberg as Service Manager
Tuesday, May 10, 2022
Coe Adds Regional Service Technicians
Friday, April 29, 2022
Automatic Feed to Provide 84-in. Blanking Line
Friday, March 4, 2022
