Die Adapters, Threading Tools, Press Brake Clamping
July 19, 2024
Wilson-Tool-FABTECH-2024-shimless-die-adapater-TrumpfWilson Tool International
Booth S27071, S28071
A host of fabrication-tool products are on display. The shimless die adapter (pictured) reportedly is the only size 1 to size 2 adjustable adapter on the market for Trumpf-style dies (see video). No more looking around for shims, nor time wasted measuring shims. Simply measure the die thickness, adjust the shimless die adapter to the desired setting, insert the die and it’s ready to go.  Save time and gain accuracy over a secondary threading application with the B-Station QuickTap. Productivity-enhancing features include the built-in fluid-injection system, the ability to tap as many as 200 holes/min., and simple-to-change pitch inserts and taps. And, press brake clamping solutions offer advantages from converting tool styles to increasing efficiency with faster tooling changeovers. Solutions include options of power clamping at the push of a button, express clamping systems with simple levers and crowning holders for deflection control, and more.
Industry-Related Terms: Die, Insert, Thickness
See also: Wilson Tool International
Technologies: Bending, CNC Punching
