Say So Long to Sheet Skeletons
January 1, 2011Trumpf Inc., Farmington, CT, introduced its new solution for dealing with messy sheet skeletons coming off of CNC punch presses: skeleton-free processing, a feature available on its TruPunch 3000 press. This innovation relies on common split cuts; however, extensive programming no longer is required to make them. Any possible geometric configuration already is programmed into the machine software, enabling the sheet layout to be optimized and prepared for the necessary release strokes.
Parts are initially processed in sequence and then freely punched prior to discharge or removal. Then, a separating tool with a bilevel stripper rotates the parts or scrap as needed to facilitate discharge via the chute, and remaining strips are completely shredded.
Trumpf officials say that the feature will increase material utilization by an average of 10 percent, and also conserve energy—peripheral equipment for cutting and disposing of scrap no longer are necessary.
Trumpf Inc.: 860/255-6000; www.us.trumpf.com
Industry-Related Terms: CNC, Material Utilization, Scrap, Stripper, Strips
See also: TRUMPF Inc.
Technologies: CNC Punching
Punch-Laser Machines Pump Life into Cellular Manufacturing S...
Brad Kuvin Friday, February 26, 2021
Brad Kuvin Tuesday, September 29, 2020
Automated Punching Cell Heating Things Up at Furnace Manufac...
Versatile Manufacturing via New Punch-Laser Combo Machine
Servo-lution Serves CNC Punching Well
Lou Kren Wednesday, February 26, 2020
